- Mon Mar 25, 2013 8:11 am
#157398
Hello, and nice forum!
I'm new to the Arduino and electronics in general... and at this point the only experience I have is completing a SparkFun Starter kit... so please excuse my lack of knowledge.
Basically, I want to control a valve with my Arduino for a science project I'm working on with my sons. Here are the specs on the valve:
Voltage Range: 0-10 vdc
Power Consumption: 1.9 watts, 2.3 watts max
Response Time: 3 to 5 ms
Circuit:
Does anyone know of some examples or tutorials for a similar solenoid operation? (most solenoid examples I've found are for simply turning the valve ON or OFF, and this is not what I want) I would like to proportionally open and close the valve with a Potentiometer I have... If that will even work.
Power:
I want to power the valve with a battery... and weight is my biggest concern. I only need to power the valve for 1 minute or less.
Does anyone have any suggestions for a lightweight battery setup for the valve in question?
Should I use a separate battery for the arduino?
Any pointers would be appreciated. I understand more learning is ideal and I certainly plan to keep it up... but I'm also anxious to get the valve at least working.
Circuit:
Power:
