- Sun Aug 04, 2013 7:50 am
#162277
I just found out the hard way that the Eagle part PSOP-8 is not pin compatible with the units you buy at newark in the DCUR housing.
Only in the PSOP-8 packaging the VREF1 pins are mixed up
PSOP-8 eagle will show
1=VREF1, 2=SCL1, 3=SDA1, 4=GND
The PCA9306DCUR
1=GND, 2=VREF1, 3=SCL1, 4=SDA1
Pin 5-8 are connected identical.
So if you use the eagle part in a PCB design with the DCUR housing it will burn off your board.
Not sure what the thinking was behind the pin mixing at TI when they introduced the PSOP-8 package
Jan
