- Tue Jul 19, 2011 10:02 am
#130409
I've been experimenting with soldering of SMD inductors. So for the experience has been less then gratifying. I'm using a hot air tool but the solder underneath doesn't want to melt. Raping up the temperature too much will most likely melt the isolation between the windings, the question is how much the choke can tolerate (the datasheet has no guidelines for this). Does anyone how some good tips? Should I just bite the apple and go with the soldering paste approche, it seems a bit to expensive just for a prototype.
Datasheet: http://www.farnell.com/datasheets/69599.pdf
