- Thu Jan 27, 2011 8:40 pm
#118599
I'm just starting out with the Arduino Uno.
I'm getting errors when downloading a sketch to the Arduino Uno when the XBee Shield and XBee Pro 60mW is connected. I don't get the errors if I remove the XBee Pro 60W from the Shield. I tried downloading the sketch with the Shield switch in both the UART and DLINE positions. Both positions had the same failed download.
What am I doing wrong?
The error message I get when the sketch fails to download are:
http://www.sparkfun.com/products/9950
This is the Shield I'm using:
http://www.sparkfun.com/products/9976
This is the XBee I'm using.
http://www.sparkfun.com/products/8742
This is the Arduino I'm using:Binary sketch size: 1018 bytes (of a 32256 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
