- Thu Dec 30, 2010 8:13 am
#116343
I'm looking for some guidance as to how the Venus GPS module should be wired up. My plan is to connect this to a FEZ Domino, I suspect I'll be using one of the COM ports.
The problem is I don't have any datasheet that describes what the various pins are used for. Some are self explanatory (Tx/Rx/VBAT/GND), but others I have no idea how they should be connected (if at all). For example, there's a CLK, is this a clock in or clock out? What is it used for?
In general can someone provide an example of "here's how you wire it up"?
