- Fri Oct 15, 2010 5:19 am
#111465
Hello to every one.
I'm not speak english very well so if I make some mistake I apologize to you in advance.
I use Altium designer 9.4 and I've encountered a problem in the PCB Designer side.
After end the schematic and updated the PCB document... I find in the PCB designer the right parts but without the connection line are visible.
- Well, for few connection is not really a probelm, but with a lot of connection is impossible to understand the righ path connections.
- Interesting thing is that if you start the Auto routing all nets are routed well.
At this point I think that is a Display error or bad setting of Preferences.
Could anyone help me please?
P.S. If I can't resolve this the only idea is to Re-Instal the software again to obtain the initial behaviour of the program.
Many thank in advance to anyone
