- Sat Nov 07, 2009 3:13 pm
#84557
LED's will change state when analog input is five or six numbers from the threshold, making accurate transitions impossible. Is there some better way to resolve this problem?
unsigned long starTime;
int flashRed = 20000;
const int numReadings = 3;
int readings[numReadings]; // the readings from the analog input
int index = 0; // the index of the current reading
int total = 0; // the running total
int average = 0;
#define blueLED 11
#define redLED 12
#define greenLED 13
#define AnIn 1
#define redThresh 670
#define blueThresh 660
#define greenThresh 0
int val;
void setup()
for (int thisReading = 0; thisReading < numReadings; thisReading++)
readings[thisReading] = 0;
starTime = millis(); //timer
pinMode(redLED,OUTPUT);
pinMode(blueLED,OUTPUT);
pinMode(greenLED,OUTPUT);
Serial.begin(9600);
void loop()
// subtract the last reading:
total= total - readings[index];
// read from the sensor:
readings[index] = analogRead(AnIn);
// add the reading to the total:
total= total + readings[index];
// advance to the next position in the array:
index = index + 1;
// if we're at the end of the array...
if (index >= numReadings)
// ...wrap around to the beginning:
index = 0;
// calculate the average:
average = total / numReadings;
//val = analogRead(AnIn);
// val = val/2;
if(average >= redThresh){
digitalWrite(redLED,HIGH);
digitalWrite(blueLED,LOW);
digitalWrite(greenLED,LOW);
delay(1000);
else {
digitalWrite(redLED,LOW);
if((average>= blueThresh) && (average <= redThresh))
digitalWrite(blueLED,HIGH);
delay(1000);
else {
if((average>= greenThresh) && (average <= blueThresh))
digitalWrite(greenLED,HIGH);
delay(1000);
else {
Serial.println(average);
