By Faraday's Cage
#77274
I have been using the "GPS Viewer" software for a Venus634LP Logger Board connected to an FT232 breakout. In the program, there is an option to set "position pinning". However, when I Googled it, I came up with nothing. Additionally, there is no binary command in the datasheet that corresponds to that option. Anyone know what "position pinning" does/means?
Thanks in advance,
Faraday's Cage
By perds
#78223
POSITION PINNING
In many applications, the position and/or velocity is represented as point on a display. To make that point appear more visually stable and/or accurate to
the end user, position pinning is implemented. In position pinning the reported position will not change unless some user-defined criteria are met.
The criteria can be set in pinning parameters.
