#67535
1. Install MSPGCC - Available http://mspgcc.sourceforge.net/
2. Compile your program (If you don’t have make, I suggest you also install cygwin)
3. Make sure you install the latest drives from olimex. Download theme from here:
a. Unzip drivers and install the MSP430.dll in the c:\mspgcc\bin directory
b. You may also need to copy over other Olimex dlls like olimex.dll, SiUSBXp.dll, etc
3. Lastly you flash your code in two steps:
a. First you set up the proxy to talk to the device with this command:
msp430-gdbproxy –port=1000 msp430 -–spy-bi-wire TI-USB-FET
The -–spi-bi-wire is KEY to talking to the msp430-pir!!!
b. Then you talk to it with this command:
msp430-gdb leds.a43 (Where leds.a43 is your test program)
>ta re :1000
4. To flash it you do this command:
>erase all
> load leds.a43
That’s it. This is the original tutorial below:
http://codewarrior.getpaidfrom.us/2009/ ... rogrammer/
