- Mon Feb 08, 2010 8:06 am
#92973
Unfortunately I got no usable replies. Other people simply use it with 2.5V, but I wouldn't do that. I use it with 2.8V and a level shifter.
mkmckenzie wrote:Just wanted to mention: I'm building a TCM8230MD with read-out done by an XMEGA (atxmega128a1... the XPLAIN demo board to be exact (8MB SDRAM!)).I don't think you have to do it this complex.
Did anyone end up selecting and using a nice level shifter for use on EXTCLK (and/or SDA/SCL) that they would recommend? I'm getting ready to use the MAX3378 but I'm getting nervous about its so-so timing specs...
So, I think I'll just use the resistor trick for EXTCLK, the Hi-Z/Output-Low trick for RESET, and use the 2 channel bi-directional shifter (MAX3373) for I2C... just to get a little of everything in there.
8bit parallel image data
1st 2nd 3rd 4th 1st 2nd
DOUT0 U0(n) Y0(n) V0(n) Y0(n+1) B0 G3
DOUT1 U1(n) Y1(n) V1(n) Y1(n+1) B1 G4
DOUT2 U2(n) Y2(n) V2(n) Y2(n+1) B2 G5
DOUT3 U3(n) Y3(n) V3(n) Y3(n+1) B3 R0
DOUT4 U4(n) Y4(n) V4(n) Y4(n+1) B4 R1
DOUT5 U5(n) Y5(n) V5(n) Y5(n+1) G0 R2
DOUT6 U6(n) Y6(n) V6(n) Y6(n+1) G1 R3
DOUT7 U7(n) Y7(n) V7(n) Y7(n+1) G2 R4
YUV mode RGB mode
lilalinux wrote:I didn't yet try YUV, but it's all explained in the datasheet (TCM8230MD.pdf) on page 12:yes i know, but if you have a look at the wikipagehttp://de.wikipedia.org/wiki/YUV-Farbmo ... arbmodells (don't think about the language, just watch the formulas) you'll see that as results for U and V, you can get values in the range of -XX.X to +XX.X and I wonder how they encoded these numbers in the YUV ouput.
Code: Select all8bit parallel image data 1st 2nd 3rd 4th 1st 2nd DOUT0 U0(n) Y0(n) V0(n) Y0(n+1) B0 G3 DOUT1 U1(n) Y1(n) V1(n) Y1(n+1) B1 G4 DOUT2 U2(n) Y2(n) V2(n) Y2(n+1) B2 G5 DOUT3 U3(n) Y3(n) V3(n) Y3(n+1) B3 R0 DOUT4 U4(n) Y4(n) V4(n) Y4(n+1) B4 R1 DOUT5 U5(n) Y5(n) V5(n) Y5(n+1) G0 R2 DOUT6 U6(n) Y6(n) V6(n) Y6(n+1) G1 R3 DOUT7 U7(n) Y7(n) V7(n) Y7(n+1) G2 R4 YUV mode RGB mode
