By jpnovak
#92612
Just got to integrating my Venus GPS breakout board to the microcontroller.
Does anyone have library, header files and basic command sets for this chip?
I am connecting through the TX/RX pins (TTL serial). I will eventually use 115200 baud and 10Hz update.
By jeanseb
#93298
jpnovak wrote:Just got to integrating my Venus GPS breakout board to the microcontroller.
I have c++ code for Visual C++ and an FTDI USB/Serial adapter if you're interested.
By jpnovak
#93350
Thank you for the offer. You have a PM.
By darkeagle
#93532
Please can you also send the code to me?
Thank you in advance.
D
By Chanler
#135547
With an ftdi board and the GPS Viewer software, you can change the nvram settings as you'd like and they'll remain set. (In case you can't find the code to set it on your controller)
