- Tue Dec 08, 2009 3:14 pm
#86754
I've been working with the 6DOF Razor and found that gyroscope bias behaves undesirably.
At zero angular rates the bias drift seems negligible; the on-board 0.034Hz 1st order HP filter is doing its job. However; during motion the bias drift seems to occor at a rapid rate; shifted by 1deg/s in just a second.
This plot should explain...
Blue trace = true angular rate measured with xsens MTx
Red trace = 6DOF Razor angular rate (gain is known to be accurate) using x-io Board: http://www.x-io.co.uk
I would concluded that the bias drift operates within the same bandwidth as the signal, therefore it is imposable to separate noise from signal!
I cannot find any mention or quantification of bias drift in the datasheet. Does anybody have any knoweldge or experience in this area?
