- Sun Jun 21, 2009 7:58 am
#75449
Hello
Im building a 1kW reverse phase dimmer (230VAC) using PIC MCU and a power MOSFET. This dimmer is designed for the dimming of ELECTRONIC transformers only. My circuit schematic is shown on the weblink.....
http://www.electro-tech-online.com/atta ... ircuit.jpg
Details of the power MOSFET (Q) in use are as follows....
# Manufacturer: INFINEON
# Manufacturer Part No: IPP60R099CPA
# Transistor Polarity: N - Channel
# Voltage, Vds Typ: 600V
# Current, Id Cont: 31A
The inductor and capacitor combination in the schematic is an RFI filter.
I simply wish to have my complete schematic cross checked for any mistakes so that the circuit can work as a reverse phase dimmer. Please can someone go through my schematic and kindly suggest any improvements that might be required. If there is any mistake, then please also point out and suggest the necessary fix.
Thank you
Haseeb
Thank you
Haseeb
