By smalcom
#58458
I comile .py with TelitPy1.5.2+_v4.1_prerelease_last and upload it to module but when i try to execute it module write
Traceback (innermost last):
  File "starter.py", line 9, in ?
    import myscript
ImportError: Bad magic number in myscript.pyo
By jasonharper
#58460
How did you upload the files? .pyo/.pyc files are binary, and will be corrupted if treated as text.
By smalcom
#58466
like .py -> ASCI mode using AT#WSCRIPT. hmmm, but file size the same.
And how upload .pyo to module?
By asmithmd1
#58503
After I installed the Telit Python tools two new options appeared under the file system when I right click on a .py or .pyo file: compile and download. I have had decent luck downloading files to my module using this option. About one out of 5 to 10 times I will get an error message and have to reboot the module before it will accept another download. This is much, much faster than downloading text files and relying on the module to compile them
By smalcom
#58517
After editing script in Lib its working with software flow,
Thx
By OBU
#59731
hi!
I make a project called OBU, and I use the GM863-GPS platform.
I have connect my PC with the DSUB of the S3-Board. Now, I have a problem with the terminal program. I receive something in binary that I don't know what that means. If somebody can help me to decode the code, I apreciate.
I just want the velocity and geographical coordinates.
By smalcom
#59736
OBU wrote:hi!
what send and what receive
