Have questions about SparkFun's ALC PCB design services? Post them here!
#239875
My current setup is the ICM-20948(https://www.sparkfun.com/products/15335) being connected to a Qwiic Cable - Breadboard Jumper(https://www.sparkfun.com/products/14425) to the arduino Uno directly.
I am running the Example basic program in the library
After uncommenting the debugging line, I received data underflow for everything possible.
I have also tried to wire both SPI(Defined SPI) and I2C and both had the same result, data underflow for everything.
Due to time constraints, I will not be able to order anything new and because of the time it will take to arrive.
I currently have the arduino uno kit and 2 qwiic connect cables.
(I am sorry if this may be a repeat but the other threads weren't helpful)
#239893
I was hoping to find what might be wrong but it didn't do anything other than give me data underflow for everything.
I'm very sure the code works because I pulled it straight from the library and the IMU is sending something to the Arduino, but it all comes out as data underflow.
 Topic permissions
