Have questions about SparkFun's ALC PCB design services? Post them here!
By Munyua44
#230759
hello all. Can anyone of you suggest where I can get the 85VAC to 85VDC voltage regulator for my project? Am trying to build a customized power supply system for my personal use.
thanks!
By rpiloverbd
#230764
Hello, I think you have to make a full-wave rectifier. Have you done that?
By Munyua44
#230776
rpiloverbd wrote: Sat Jan 15, 2022 8:45 am Hello, I think you have to make a full-wave rectifier. Have you done that?
my problem is the type of the diode that i should use in the full wave rectifier now. How can i do those calculations, also how do I know the size of the capacitors to smoothen the output?
By Munyua44
#230978
rpiloverbd wrote: Sun Jan 16, 2022 9:47 am You can either build a bridge by using 1N4007 diodes, or directly can use a bridge rectifier IC like this one: https://drive.google.com/file/d/1YJdV4o ... 3KhPK/view
Regarding the capacitor, you may find this video helpful: https://www.youtube.com/watch?v=J9HsLWmtBnE
Your guidance was so amazing. I have fully implemented my project. Your video helped in the calculation of the capacitance required and selection of the best capacitors to use. I also came across another article about the full wave rectifier and how i should simulate it on proteus to confirm that actually it was a functional circuit. See the article on this link https://www.theengineeringprojects.com/ ... oteus.html
 Topic permissions
