- Thu Nov 11, 2021 5:58 pm
#229602
I changed the OpenLog_Artemis_V10-v20 firmware to use the Qwiic IR Thermometer - MLX90614 sensor.
I made two different implementations, one uses the SparkFunMLX90614.h library and the other implementation uses the Adafruit_MLX90614.h library. In both implementations I have the same problem, when reading the I2C data the values I get are always at a high level. I believe I will have to use a logic level converter. I tested it with Arduino Uno and had no problem. Does anyone have any ideas?
