- Sun Nov 07, 2004 4:29 pm
#2166
hi all
I am trying to get the module up and running but no luck so far
(writing my own code). Here is a couple questions:
1) Do I have to transmit exact number of bits that have been configured or it can be less then that ?
2) When I want to switch between Tx and Rx mode, do I have to load whole last byte into config, or just one bit 0 ? From the docs I think it should be enough to load one bit, but in the SMIRF firmware source it is one byte, including channel number...
3) how can I detect if something actually sent through air ? I am working on two modules at the same time (Tx Rx) and there is no transmission, is there any way to detect if it is Rx device or Tx device problem ?
