- Thu Feb 15, 2018 7:49 am
#198330
Hi, i tried to get a usable answer on a different forum but so far what ive got is "do this thing you dont know how to do that we arent going to answer in a way that is at all usefull to you" and im hoping someone here can give me an answer i can use. i am upgrading a TRON legacy deluxe disc and i am using two arduino pro trinkets and a three position slider switch. i want the middle (im calling it position 2) to be "off, position one, the left, will power ONLY the inner "C" ring for a carry and display mode while position 3, the right side, will power up BOTH boards so the inner "C" ring and the blade will both light up for an "active" mode. i was told to use a diode, which i understand how they work, but i have no clue how to wire it in. the switch has two groups of four contact pins. the way i see it is i can wire one board to the first position and then both boards to the second set of pins but i need to know if that would work, or how it is to wire a diode into this
