- Mon Oct 21, 2013 8:57 am
#164688
Hi folks. I built this for a DJ friend of mine and he loves it. One issue is the RCA jacks produce some what of an Echo. He calls he calls a warble sound. The small phono-out does not do this, clear. This is what it sounds like clear:
http://www.youtube.com/watch?v=KXc-cXVO40E
For those of you who don't know, the PHONE has a DC Bias, and it is recommended that you decouple it as shown by these links:
http://www.sparkfun.com/datasheets/Widg ... output.pdf
"Par 3 - Line-out Connection It’s not recommended to use GBUF as audio ground when connecting to other electrical equipment such as power amplifiers or PC line-inputs. The GBUF pin is internally biased to 1.25V and it is possible that a ground loop is formed when the GBUF is connected to the ground of the target device. This may damage the
VS10XX device and will prevent normal operation."
Or this link: http://www.zachpoff.com/diy-resources/i ... 3-trigger/
![Image](http://www.zachpoff.com/site2/wp-content/uploads/MP3-Trigger-line-out-circuit-274x300.jpg)
Here is the project. You can see I put in the 100 ohm resistor in series, with 10uf cap, and a 10K resistor to ground for each channel.
![Image](http://imageshack.us/a/img834/1838/0ing.jpg)
![Image](http://imageshack.us/a/img443/426/3nlx.jpg)
![Image](http://imageshack.us/a/img802/3900/vkl7.jpg)
