- Sat Jan 14, 2012 2:02 pm
#138225
I'm trying to build an airsoft gun shot counter.
The first step was getting an Arduino to control the motor. Airsoft motors draw high loads from 6v-18v batteries (I want to use an 11.1v LiPo). I picked up a Sparkfun MOSFET breakout board http://www.sparkfun.com/products/10256 to make my life easier (I'm not an electrical engineer, not even close) during the prototyping phase. I swapped out their MOSFET for a higher rated MOSFET. I know the circuit limitations are probably on the circuit board traces, not the MOSFET, but I'm only prototyping this on a bench right now. Eventually I'm going to have to tackle the problem of massive electrical traces (again, I'm trying to go in small, easy steps).
I rigged everything together today on my workbench. I was stunned when everything worked. I push the button, and the gearbox fires. I let go of the button, and it stops.
I'm trying to figure out how to actually count the number of shots. Before I even tried to trigger the gun with a microprocessor, I tried to measure the number of shots with a photo-interrupter attached to the barrel.... I had issues with that. Eventually I want to get back to that, but right now I'm trying to approach it from a different angle.
An airsoft motor works cyclically. It's an electric motor (similar to the brushed motors in RC cars). However, it fires the airsoft pellet by compressing and then releasing a spring. It has periods where it has to work (very hard) to compress the spring, and then "free periods" where the spring has been released.
Is there a way to measure those periods using the Arduino's analog inputs? Can I measure the amps drawn by the motor? I'm thinking that this would allow me to monitor the electrical situation of the airsoft gun.
Where would I measure it from? How do I protect the Arduino from electrical spikes inherent to this project?
Static
