- Sun Feb 06, 2011 6:02 am
#119416
i have developed my own board with the wifly rn131-g module and have some problems to bring the module into service.
the module is connected via the uart with an ARM7 LPC2388 Microcontroller. after reading the user manual i send these three chars "$$$" an the module gave me this message back:
Auto-Assoc roving1 chan=0 mode=NONE FAILED<CR><LF>*RE
now the manual says the module should give this back : "CMD" to enter command mode and configure the module. then i tried to put the PIO[9] Pin on High with the 4 DIL switcher. after turning on the power supply and debugging again the module now sends me CMD back, but still some problems remain. when i try the "show net" or "scan" order i dont get valid messages back e.g. "show net" i only get "SSID=" and after that 0xFFFF. and "scan" i only get "Disablen.." and then 0xFFFF over the uart.
i am using the IDE "keil uVision" and the "Keil ULINK2 Debugger"
