Generate pulses
Posted: Mon Jul 18, 2016 12:46 am
I am making the program in msp430g2553 launchpad. In this my input is from pin2.4. and my output will be three pulses from pin2.0, pin2.1, pin2.2. The code i am posting here in this the output i am getting is from pin2.0 high pulse, from pin2.1 low pulse and from pin2.2 high pulse.
I want all the three low pulses.
can anyone help me with this.
#include <msp430g2553.h>
#define CPU_F ((double)16000000)
#define delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
int i;
char C_1, C_2;
void System_Clock_Init( void )
char i;
_NOP();
WDTCTL = WDTPW + WDTHOLD; // Close Watching dog
delay_ms(20); // 1MHz
if( ( CALBC1_16MHZ == 0xff ) || ( CALDCO_16MHZ == 0xff ) ) // FLASH A was cleared!!!
((void (*)())RESET_VECTOR)();
BCSCTL1 = CALBC1_16MHZ; //ACLK=32768Hz
DCOCTL = CALDCO_16MHZ; //MCLK=DCOCLK=16MHz
BCSCTL2 = 0x06;//SMCLK=DCOCLK/8=2MHz
BCSCTL3 = 0x00;//cap=1pF
IE1 &= ~OFIE;//close crystal error interrupt
TA0CCR0 =32-1; // PWM Period --> needs to be adjustable
TA0CCTL1 = OUTMOD_2; // CCR1 reset/set
TA0CCR1 = CCR0/2; // CCR1 PWM duty cycle 50% -->needs to be adjustable
TACTL = TASSEL_1 + MC_1; // SMCLK, up mode
do
IFG1 &= ~OFIFG;
for( i = 0; i < 100; i++ )
_NOP();
while (IFG1 & OFIFG);
_NOP();
void IO_INIT(void)
P2SEL &= ~BIT4;
P2SEL2 &= ~BIT4;
P2REN &= ~BIT4;
P2DIR &= ~BIT4;
P2DIR |= BIT2;
P2IES |= BIT4;
P2IE |= BIT4;
P2IFG &= ~BIT4;
P2SEL &= ~(BIT0+BIT1);
P2SEL2 &= ~(BIT0+BIT1);
P2REN &= ~(BIT0+BIT1);
P2DIR &= ~(BIT0+BIT1);
P2DIR |= (BIT0+BIT1);
P2OUT &= ~(BIT0+BIT1);
P2SEL &= ~BIT2;
P2SEL2 &= ~BIT2;
P2REN &= ~BIT2;
P2DIR &= ~BIT1;
P2DIR |= BIT1;
P2OUT &= ~BIT2;
void main(void)//29uA
System_Clock_Init();
_NOP();
//WDTCTL = WDT_ARST_1000;//feed watch dog ?????下面的程序执行时间???
_NOP();
IO_INIT();
_NOP();
_EINT();//open all interrupt
_NOP();
LPM3;
_NOP();
while(1);
//Function: Start Timer 0 A0 for Hour Timing 500ms
#pragma vector = PORT2_VECTOR
#pragma vector = TIMER0_A1_VECTOR
__attribute__((__interrupt__(TIMER0_A0_VECTOR)))
void Timer0_A(void)
_NOP();
delay_us(20);
if( C_1 == 0xff)
if(!( P2IN & BIT4 )) C_2 = 0xff;
else
if(!( P2IN & BIT4 )) C_1 = 0xff;
if(( C_1 == 0xff) && ( C_2 == 0xff))
//output A B D
P2OUT |= BIT1;
P2OUT |= BIT0;
delay_ms(2);
P2OUT |= BIT2;
P2OUT &= ~BIT0;
delay_ms(2);
P2OUT |= BIT2;
P2OUT &= ~BIT1;
//delay_ms(2);
P2OUT &= ~BIT2;
P2OUT &= ~BIT1;
delay_ms(2);
C_1 =0x00;
C_2 =0x00;
_NOP();
