- Sat Aug 26, 2006 6:04 pm
#17980
eZ430-F2013 (the little USB gadget) does not work with Windows 98 because Windows 98 does not *fully* support USB. The target interface
of that little USB gadget consists of 4 wires (Spy-Bi-Wire). IAR debugger
supports that.
When you use Parallel Port FET, IAR only supports JTAG-4-Wire. Thus
you have to solder 8 wires. Use up 8 pins on a 14 pin uC is too much.
I think you should be able to use the little USB gadget (under Windows 2K
or XP) to do in circuit emulation. I think what you need to do is:
(a) Unplug the tip section (F2013+LED) from the USB section.
(b) Connect 3 wires to your board, GND, RST, and TEST.
supports that.
