Turning off interrupts in ISR
stube40
Post by stube40 » Sun Aug 21, 2011 6:00 pm
My interrupt service routines generally look like this:
#pragma vector = PORT1_VECTOR
__interrupt void PORT1_ISR(void)
__disable_interrupt(); // Disable global INTs so nothing can interrupt this ISR
// General content of ISR
__enable_interrupt(); // Re-enable global INTs
I was wondering - is it necessary to manually disable/enable interrupts as I currently do, or does IAR automatically look after this for you when it compiles hence making my calls to __disable_interrupt() and __enable_interrupt() redundant?
UhClem
Re: Turning off interrupts in ISR
Post by UhClem » Mon Aug 22, 2011 7:56 am
stube40 wrote: I was wondering - is it necessary to manually disable/enable interrupts as I currently do, or does IAR automatically look after this for you when it compiles hence making my calls to __disable_interrupt() and __enable_interrupt() redundant?
Read the user guide for the particular MSP430 family you are using. I checked one to verify my memory of interrupt processing:
"The SR is cleared. This terminates any low-power mode. Because the GIE bit is cleared, further
interrupts are disabled."
The hardware does it.
stube40
Post by stube40 » Mon Aug 22, 2011 9:34 pm
Many thanks!
