- Tue Feb 28, 2006 8:00 am
#10452
I am using the MSPGCC toolchain on Windows 2000. I have succesfully built and downloaded the easyweb example to the EasyWEB3 board. My problem is when I recompile for MSP430F1611 prototype board or header board I can't download (see transcript below) I suspect the boards since my tools work with the EasyWEB3 board. Also the MSP430F1611 boards send a disturbing message to the console port "Short with GND" on power-up.
Has anyone sucessfully used the MSP430F1611 proto or header board?
Any ideas?
D:\mspgcc\examples\tcpip>make clean
rm -f easyweb easyweb.o tcpip.o cs8900.o
msp430-gcc -c -g -O2 -mmcu=msp430x149 -c -o easyweb.o easyweb.c
msp430-gcc -c -g -O2 -mmcu=msp430x149 -c -o tcpip.o tcpip.c
msp430-gcc -c -g -O2 -mmcu=msp430x149 -c -o cs8900.o cs8900.c
msp430-gcc -mmcu=msp430x149 -oeasyweb easyweb.o tcpip.o cs8900.o
D:\mspgcc\examples\tcpip>msp430-jtag -e easyweb.elf
MSP430 parallel JTAG programmer Version: 2.1
Mass Erase...
Program...
9714 bytes programmed.
Reset and release device...
If I attempt to download to the MSP430F1611 prototype board I get the following result;
D:\mspgcc\examples\tcpip_msp4301611>make clean
msp430-gcc -c -g -O2 -mmcu=msp430x1611 -c -o easyweb.o easyweb.c
msp430-gcc -c -g -O2 -mmcu=msp430x1611 -c -o tcpip.o tcpip.c
msp430-gcc -c -g -O2 -mmcu=msp430x1611 -c -o cs8900.o cs8900.c
msp430-gcc -mmcu=msp430x1611 -oeasyweb easyweb.o tcpip.o cs8900.o
D:\mspgcc\examples\tcpip_msp4301611>msp430-jtag -e easyweb.elf
Cleaning up after error...
An error occoured:
Can't open interface
Clearly I dont' expect this image to run properly since the board doesn't have a CS8900 chip but it should download properly. I suspect some problem with the MSP430F1611 prototype board. I have tried this on two differend boards. Curiously when I power the MSP430F1611 prototype board the serial port emits the following;
WWW.OLIMEX.COM/DEV
Short with GND
I don't know what image comes preloaded on the MSP430F1611 prototype board but if it is diagnostic, it seems to be reporting a problem.
Any ideas?
Mass Erase...
Program...
An error occoured:
WWW.OLIMEX.COM/DEV
Short with GND
Bill
