Interfacing with an LCD
Posted: Thu Apr 23, 2009 5:49 pm
I am having problems interfacing my LCD with my msp430f149. The LCD has work before for some time and then it just stop working for some reason and I ain't able to get to initialize and show characters properly until a random time in the future. I am sending my initialization code:
#include "msp430x14x.h"
#include "stdlib.h"
//Ports and Function List
//MSP LCD Function
//P1.5 P4 RS 0I-1D
//P1.6 P5 R/W 0W-1R
//P1.7 P6 E
//P2.0 P7 DB0
//P2.1 P8 DB1
//P2.2 P9 DB2
//P2.3 P10 DB3
//P2.4 P11 DB4
//P2.5 P12 DB5
//P2.6 P13 DB6
//P2.7 P14 DB7
void wait(long milliseconds){
int ms=0;
int i=0;
int j=0;
int k=0;
for(ms=0; ms<milliseconds; ms++){
for(i=0; i<16; i++){
for(j=0; j<250; j++){
for(k=0; k<10; k++);
void clearLCD(){
P1OUT &= ~0xF0; //and.b 00001111b,P1OUT
P1OUT |= 0x80; //Enable or.b 10000000b,P1OUT
P2OUT = 0x01; //mov.b 00000001b,P2OUT
wait(5);
P1OUT &= ~0x80; //Disable and.b 01111111b,P1OUT
wait(5);
void initializeLCD()
//Clear pins
P1OUT &= ~0xF0;
P2OUT = 0x00;
//Set directions
P1DIR |= 0xF0;
P2DIR |= 0xFF;
//Clear pins
P1OUT &= ~0xF0;
P2OUT = 0x00;
wait(15);
//Initializes LCD to 2 lines.
P2OUT = 0x3C;
wait(4);
wait(4);
P2OUT = 0x3C;
wait(4);
wait(4);
P2OUT = 0x3C;
wait(3);
wait(3);
P2OUT = 0x3C;
wait(3);
wait(3);
//Display Off
P2OUT = 0x08;
wait(3);
wait(3);
clearLCD();
//Entry Mode Set (Display on, Cursor blinking command)
P2OUT = 0x06;
wait(3);
wait(3);
//Outputs this command to the LCD
void LCD_command(unsigned char var){
P1OUT &= 0x0F;
P2OUT = var;
wait(3);
P1OUT &= 0x7F; //Disable
wait(3);
//Outputs the ASCII code from the var through P2
void LCD_senddata(unsigned char var){
P1OUT |= 0x20;
P2OUT = var;
wait(3);
wait(3);
//This function displays the first 7 characters of a string in the specified position
void LCD_sendstring(unsigned char pos, char string[] ){
int x = 0;
LCD_command(pos);
while(string[x] != '\0'){
LCD_senddata(string[x]);
x++;
// This function displays all characters from String mess.
void LCD_message(char mess[]){
int x = 0;
while(mess[x] != '\0'){
LCD_senddata(mess[x]);
x++;
void writeSelections(int selection, char upLeft[], char upRight[]){
LCD_command(0x01); //LCD clear command, just in case.
if(selection == 1){ //Will display all strings with an arrow on the first position
LCD_command(0x80); // Set Ram location to first character in LCD
LCD_senddata(0x7E); // Arrow ASCII code
LCD_sendstring(0x81, upLeft); // First String on first position
LCD_sendstring(0xC1, upRight);
}else if(selection == 2){
LCD_senddata(0x7F);
}else if(selection == 3){
LCD_command(0xC0);
LCD_senddata(0x7E);
}else if(selection == 4){
LCD_command(0x81); // Set Ram location to first character in LCD
LCD_senddata(0x7F);
void write(int selection, char message[], char option1[]){ //Works exactly like writeSelection.
LCD_command(0x01); // Clear LCD just in case
if(selection == 1){
LCD_message(message);
LCD_command(0xC0);
LCD_senddata(0x7E);
LCD_sendstring(0xC1, option1);
LCD_command(0xC0);
LCD_senddata(0x7F);
}else if(selection == 0){
LCD_command(0xC0);
int main(void){
char test[] = "This is a test";
char option1[] = "Ok Cancel";
WDTCTL = WDTPW + WDTHOLD;
initializeLCD();
write(2,test,option1);
Any response will be appreciated. Dont hesitate to ask me for additional information.
#include "stdlib.h"
//MSP LCD Function
//P1.5 P4 RS 0I-1D
//P1.6 P5 R/W 0W-1R
//P1.7 P6 E
//P2.0 P7 DB0
//P2.1 P8 DB1
//P2.2 P9 DB2
//P2.3 P10 DB3
//P2.4 P11 DB4
//P2.5 P12 DB5
//P2.6 P13 DB6
//P2.7 P14 DB7
int ms=0;
int i=0;
int j=0;
int k=0;
void clearLCD(){
wait(5);
wait(5);
//Clear pins
P1OUT &= ~0xF0;
P2OUT = 0x00;
//Set directions
P1DIR |= 0xF0;
P2DIR |= 0xFF;
//Clear pins
P1OUT &= ~0xF0;
P2OUT = 0x00;
wait(15);
P2OUT = 0x3C;
wait(4);
wait(4);
P2OUT = 0x3C;
wait(4);
wait(4);
P2OUT = 0x3C;
wait(3);
wait(3);
P2OUT = 0x3C;
wait(3);
wait(3);
//Display Off
P2OUT = 0x08;
wait(3);
wait(3);
clearLCD();
P2OUT = 0x06;
wait(3);
wait(3);
P1OUT &= 0x0F;
P2OUT = var;
wait(3);
wait(3);
P1OUT |= 0x20;
P2OUT = var;
wait(3);
wait(3);
int x = 0;
LCD_command(pos);
x++;
int x = 0;
x++;
LCD_senddata(0x7F);
LCD_command(0xC0);
LCD_senddata(0x7E);
LCD_senddata(0x7F);
if(selection == 1){
LCD_command(0xC0);
LCD_senddata(0x7E);
LCD_command(0xC0);
LCD_senddata(0x7F);
LCD_command(0xC0);
int main(void){
initializeLCD();
