By betaar
#58918
I have purchased the MSP430-PIR module and MSP430-JTAG from sparkfun. I want to modify the firmware provided by ti.com for the application. I am not able to download the firmware to the MSP430f2013 in the PIR module using the JTAG connector. I am using IAR compiler.
Error message says - Emulator - "No device found .................."
Any suggestion would be appreciate.
Thanks in advance
By leon_heller
#58943
Have you installed the drivers?
Leon
By betaar
#58967
Hi Leon,
Thanks for your reply. I have installed the drivers. I also did test the MSP430-PIR board even by changing the jumper settings but nothing seems to work.
It is not able to detect the MSP430.
Thanks,
By leon_heller
#58972
Which JTAG are you actually using?
Leon
By leon_heller
#59003
I thought you might be using one of the USB units. It should just work, you don't need drivers for it.
Leon
By betaar
#59020
Thanks...i will get an USB Jtag for programming
By daubin327
#66945
The parallel jtag programmer doesn't support spy-bi-wire. You'll need at least the msp-jtag-tiny to program via spy-bi-wire.
