By sid_s
#58441
1. Connect JTAG header of USB FET to JTAG1 to debug the FG4618
2. Open IAR Embedded Workbench V 3.42.
3. Choose Project􀃆 Add Existing Project from the drop down menu.
4. Select the project file the FG4618 host_comms.ewp from the Labs directory.
5. Confirm if the target is MSP430FG4618 and FET Debugger option is selected.
6. Build and load the project on the device by selecting Project􀃆 Debug.
7. Come out of Debug mode by selecting Debug􀃆Stop Debugging.
8. Disconnect JTAG header of USB FET from JTAG1 and connect it to JTAG2 debug the F2013.
9. Choose Project􀃆 Add Existing Project from the drop down menu.
10. Select the project file F2013 touchbutton.ewp or F2013 touchpad.ewp from the Labs directory.
11. Confirm if the target is MSP430F2013, FET Debugger and Spy-Bi-Wire interface is selected.
12. Build and load the project on the device by selecting Project􀃆 Debug.
13. Cycle power to the FG4618 based on its power selections to start its operation.
14. From the IAR Embedded Workbench window from the drop down menu select Debug􀃆 Go to start operations on the F2013.
15. The LCD would activate a three-digit display.
16. Experiment with this setup using instructions provided starting from Page 9 of the document “Hands-on Capacitive touch sensing with MSP430.pdf” to see the effects of running a capacitive sensitive touch button demo
Can any one please tell me how to perform step 13
By FartingMonkey92
#58473
Where it says "cycle power", i would assume you just turn it off and on again?
Just having a guess... :?
