By luisvc91
#206127
I am working with ADXL345 sensor and the Sparkfun library.
I have some questions about the library....
Here is the code
/*************************** RATE BITS ******************************/
double ADXL345::getRate(){
	byte _b;
	readFrom(ADXL345_BW_RATE, 1, &_b);
	_b &= B00001111;
	return (pow(2,((int) _b)-6)) * 6.25;
void ADXL345::setRate(double rate){
	byte _b,_s;
	int v = (int) (rate / 6.25);
	int r = 0;
	while (v >>= 1)
		r++;
	if (r <= 9) {
		_s = (byte) (r + 6) | (_b & B11110000);
		writeTo(ADXL345_BW_RATE, _s);
1.- In the funcion geRate, what does "(pow(2,((int) _b)-6)) * 6.25" do? I could not understand it....
2.- In the funciton setRate:
2.1.- Why do I do " int v = (int) (rate / 6.25)"??
2.2.- In general, I can understand anything about that from int r=0...
Thank you for your help.
Best regards,
Luis
