Questions &/or issues related to products in the Movement & IMU category should be posted in this forum.
#204280
I have programmed the SparkFun 9DoF IMU Breakout - LSM9DS1 with my Particle.IO dev kit.
With the LSM9D21 library (GitHub), I am reading x,y,z values for gyro, accel and magnet ICs .
I have two questions:
1. So for gyro x,y,x values, these are being calculated as dps:
Gyro: -0.74, -0.04, 0.39 deg/s
My requirement is to calculate the absolute values not the rate of change. How can I do that?
2. I also need to calculate Azimuth (i.e. direction north, east, south, west?) and Elevation? Can I do this with this IC?
Thanks,
SYED
#204401
Hey Syed. Thanks for posting on the forums.
I regret to say that the extent of my knowledge on this product is limited to the hook-up guide and the code that we use to show that the product is running according to the specifications in the code.
Considering this product is primarily on a breakout board, I would imagine that studying the datasheet for the chip onboard is your best course of action for understanding if this sensor can accomplish what you need for your project:
https://cdn.sparkfun.com/assets/learn_t ... asheet.pdf
You may also want to post on the ST forums and see if a seasoned Support Moderator can assist you or see if someone in the community can point you in the right direction:
https://community.st.com/s/
I wish you the best and apologize that I do not have a better answer.
