- Thu Mar 22, 2007 4:17 pm
#27640
Hi all,
Well, I've been thrown a atmega32 problem (a friend is doing some programming).
I've not used a atmega32 before, and he is using the iar compiler, so my knowledge on that uP is limited at best.
Here it is, simple I'm sure...
I have 4 io pins, lets say:
PB0
PB1
PC0
PC1
I want these pins to be
#1. High
#2. Low
#3. Float - High-Z
From what I can see, I can adjust the direction of the ports by adjusting the DDRx register
DDRB and DDRC
A "1" bit means output for that pin
A "0" bit means input for that pin
How do I do a float or high-Z state?
Any Thoughts?
~Kam (^8*
PB0
PB1
PC0
PC1
#1. High
#2. Low
#3. Float - High-Z
DDRB and DDRC
Any Thoughts?
~Kam (^8*
"Before you criticize someone, you should walk a mile in their shoes.
That way, when you criticize them, you're a mile away and you have their shoes."
