Test program for avr using bascom-avr compiler
Locked
IDOGE
Contact:
Post by IDOGE » Tue Aug 24, 2004 2:21 am
I am a newbie in avr programming. I got a couple of avr, bascom-avr compiler but I don't have a good test code.Can some one help me with a test code in basic , for example blinking a LED.
pic for all
Caffeine
Re: Test program for avr using bascom-avr compiler
Post by Caffeine » Sat Feb 19, 2005 7:24 am
IDOGE wrote:I am a newbie in avr programming. I got a couple of avr, bascom-avr compiler but I don't have a good test code.Can some one help me with a test code in basic , for example blinking a LED.
Have a look at some of the samples, the DT006 one in particular is quite simple
idtat
Here is a flash LED prog
Post by idtat » Sun May 14, 2006 10:05 am
$regfile = "attiny2313.dat"
$crystal = 10000000
Config Portb.7 = Output
Main:
Portb.7 = 1
Waitms 20
Portb.7 = 0
Waitms 10
Goto Main
End
Remember to remove J2 when programming then replace it to flash
I used the PonyProg to program the chip
Aaron
Locked
Return to “Code”
