By bsuhel
#116089
Hello
There is example1(from 10) from basic code, in whille i will send here code for CDC and HID USB comunication. (For fun) . You can see what can you do with 1 led , 1 button and USB comunication. For USB communication related source you have to have USB add on and Bascom licence.
'Vega Mini - Develop board
'Test tipke HWB(PE.2) in led diode (PE.3)
$regfile = "usb1287.dat"
$crystal = 16000000
Porte = &B00000000
Ddre = &B00001000
Do
If Pine.2 = 0 Then
Reset Porte.3
Waitms 50
Set Porte.3
Waitms 50
Else
Reset Porte.3
Waitms 100
Set Porte.3
Waitms 100
End If
Loop
