- Mon Feb 15, 2010 9:41 am
#93557
Can I use analogWrite() PWM simultaneously on multiple pins without any timing problems? If there are timing issues, does their badness depend on the number of different PWM channels I use? The duty cycles on each pin will be different from each other. And if it's not possible to do this without timing badness, I'm interested in any suggestions about alternatives you might have.
I'm interested in learning about this behavior for both the Duemilanove (6 PWM channels) and the Mega (13 PWM channels).
Thanks.
-- equipoise
Thanks.
-- equipoise
