Psuedocode implementation of ADD?
Stevetronics
Post by Stevetronics » Wed Jan 20, 2010 1:42 pm
I have a coding problem. I'm in the process of writing an AVR ATmega168 simulator/emulator for my Ubuntu box, and yes, It'll be open source when I'm done. I'm looking for a way to implement the ADD instruction in java. ADD adds two registers without carry. I'm not really sure how to do that. Should I just implement a binary adder in code? I'm not sure what route to take. If anyone has an efficient suggestion, I'd be very grateful. Thanks!
"Oh, you have to plug it into the wall!" - Just before 120VAC hit his 'Mega168.
tetsujin
Contact:
Re: Psuedocode implementation of ADD?
Post by tetsujin » Wed Jan 20, 2010 1:58 pm
Stevetronics wrote:I have a coding problem. I'm in the process of writing an AVR ATmega168 simulator/emulator for my Ubuntu box, and yes, It'll be open source when I'm done. I'm looking for a way to implement the ADD instruction in java. ADD adds two registers without carry. I'm not really sure how to do that. Should I just implement a binary adder in code? I'm not sure what route to take. If anyone has an efficient suggestion, I'd be very grateful. Thanks!
I don't get it. Why not just read in the two registers into integers and add them together, set the carry flag if the answer is over 255, and store the bottom 8 bits of the result into the target register?
(Actually I guess you need to set other SREG flags as well: H, S, V, N, Z, and C. But still...)
---GEC
OrlandoArias
Post by OrlandoArias » Wed Jan 20, 2010 3:21 pm
You may want to take a look at
http://gitorious.org/simavr
Stevetronics
Yup/.
Post by Stevetronics » Wed Jan 20, 2010 4:25 pm
The SREG flag was the way to go. I tracked down Atmel's AVR instruction set info (not hard) and went with that. I'm working on it as we speak. Well, not quite. I have 2 tests, a quiz, and a paper tomorrow, so It'll have to wait. :(
Halfbubble
Post by Halfbubble » Thu Jan 21, 2010 12:59 pm
My coding problems are usually related to ADD, but not the instruction :lol:
