reading voltage from analog pin
keithg
Post by keithg » Sat Oct 03, 2009 2:02 pm
I have tested an LM386 circuit with multimeter and a small speaker so I know it is functional but I can't read meaningful values with this code
  int soundLevel =  analogRead(0) -512;
  Serial.print( "soundIn = ");
  Serial.println(soundLevel);
 delay (1000);
I would appreciate advise.  Thanks.
Liencouer
Post by Liencouer » Tue Oct 06, 2009 6:49 am
What are you trying to accomplish? How is the speaker/audio amp related to the analog input? What do you have hooked up to analog pin 0?
