PIC Code
Posted: Thu Apr 28, 2005 6:44 am
by RITZ
[edit] I posted this in wrong section, can someone move it to PICs?
I am trying to turn on PORTA when RB0 (bit0 of PORTB) gets input. But PORTA doesn't turn on when I give +5V to RB0.
	#include <p18f1320.inc>
	__config _CONFIG1H, 0x04; external oscillator
	__config _CONFIG2L, 0x00; PWRT and brown out off
	__config _CONFIG2H, 0x00; PWRT and brown out off
	__config _CONFIG4L, 0x80
main
; all outputs
	CLRF TRISA; outputs
	SETF TRISB;inputs
; init
	CLRF PORTA
	CLRF PORTB
checkagain
	MOVLW b'00000001'; bit 0
	ANDWF PORTB, 0
	BZ checkagain
	SETF  PORTA,0; turn on port a
	GOTO checkagain
	END
Posted: Thu Apr 28, 2005 7:31 am
by jasonharper
RB0 is an analog pin by default on that PIC, and will therefore read as 0 until it is configured as a digital pin (see the ADC section of the datasheet).
Also make sure you're applying the input to the right pin - for some bizarre reason, the 18F1xxx parts have a slightly different pinout than other 18-pin PICs.
Posted: Thu Apr 28, 2005 7:45 am
by RITZ
Oh.. ok, how do I change it to digital?
*tries using RB2*
[EDIT]
I tried RB2 wich is digital and the LED just always stays on without the input.
	__config _CONFIG1H, 0x04	; external oscillator
	__config _CONFIG2L, 0x00		; PWRT and brown out off
	__config _CONFIG2H, 0x00		; PWRT and brown out off
main
	; all outputs
	CLRF TRISA ; outputs
	SETF TRISB ;inputs
; init
	CLRF PORTA
	CLRF PORTB
checkagain
	MOVLW b'00000100' ; bit 0
	ANDWF PORTB, 0
	BZ checkagain
	SETF  PORTA,0 ; turn on port a
	GOTO checkagain
Posted: Thu Apr 28, 2005 7:56 am
by jasonharper
The digital/analog status of pins is set via one of the ADCONx registers (and CMCONx on parts with comparators). You need to check the datasheet, details vary widely between parts.
As currently written, your program will turn on PORTA the first time the input is seen high, and then leave it on forever - you have no code to turn PORTA back off. Could that explain the results you're seeing?
Posted: Thu Apr 28, 2005 8:02 am
by RITZ
That is all I am trying to do. It is just for learning I/O.
Posted: Thu Apr 28, 2005 8:08 am
by RITZ
Hmm.. the led is still turning on before I say.
main
	MOVLW 0x70 ; Configure A/D
	MOVWF ADCON1 ; for digital inputs
	; all outputs
	SETF TRISB ;inputs
; init
	CLRF PORTA
	CLRF PORTB
checkagain
	MOVLW b'00000001' ; bit 0
	ANDWF PORTB, 0
	BZ checkagain
	GOTO checkagain
0x70 Sets RB0, RB1, RB4 as digital IO pins.
