- Mon Dec 18, 2006 11:31 pm
#23890
I have a strange problem.
Your USB JTAG has been working perfectly in one machine which has AVR Studio v4.12 SP2 Build 472. There it connects in COM7.
When I try the same unit in another machine, I have problems. This is how the sequence goes.
I connect the USB side to the Laptop. Driver gets installed and the device is ready for use. It is assigned to COM8.
I connect JTAG to the Board. The LED glows.
I start AVR Studio and try to connect, using the CONNECT diaglog box.
The LED goes off.
I get this message.
"AVR Studio has detected a JTAG ICE with an old firmware version....
..... Select CANCEL to abort upgrade. You will not be able to continue.."
When I press OK, I get another message.
"No Supported board found! AVRProg version 1.40
When I press OK, the next screen displays the usual Connect diaglog box.
And I am stuck. In this machine, AVR Studio v4.12 SP4 Build 498 is installed.
Both the laptops are on Windows XP.
What shall I do now. Should I uninstall the latest Studio and go back to the older version. But it is unlikely that I will get the old version now.
Regards,
kps
Although I have enabled HTML in my profile, I find HTML is still OFF. I am unable to paste the screenshots of error messages.
The LED goes off.
I get this message.
Regards,
kps
