Openlog pin configuration
ndhambi
Post by ndhambi » Fri Mar 24, 2017 5:33 am
I have redesigned the sparkfun open log board due to size constraints on my design, i have used the same components as the ones on the Sparkfun Open log, However i have used different pinouts on the ATMEGA328, I wanted to find out if there is a way i can modify the openlog firmware/software pin configuration?
Regards
Nyiko
jremington
Re: Openlog pin configuration
Post by jremington » Fri Mar 24, 2017 3:23 pm
Openlog is open source. Download the code and modify it any way you wish.
ndhambi
Post by ndhambi » Mon Mar 27, 2017 12:52 am
jremington wrote:Openlog is open source. Download the code and modify it any way you wish.
I understand that it is an open source but i cliuldnt find the file where they do the pin out definations
jremington
Post by jremington » Mon Mar 27, 2017 9:48 am
The pinout definitions are part of the Arduino IDE, and can be found in the supplied source code.
Perhaps if you explained what you want to do, you would get an informed answer.
