Trouble recognising atmega8, fuse setting issue
Posted: Tue Jan 06, 2015 6:33 pm
I am very new to the world of microcontrollers and after messing around with the arduino ide with a uno development board I decided to make a breadboard development board in order to accelerate learning
I chose the atmega8 as it seemed like a popular choice for breadboard made development boards
I purchased a freetronics usbasp programmer and got hooking it all up
From what I understood the atmega8 has an internal oscillator??? I hooked up an 8MHz crystal anyway as that is what everyone else seemed to do to get it to work
The following is all using avrdude in linux
Initially it could not pick up the mcu, this was fixed by attaching jumper leads over slow clock pulse on the usbasp (why is this the case?)
Wrote a simple program in assembler to turn on an led, flashed the mcu, led comes on!!! Success!!!
Now here is where everything goes wrong.
So from what I understand even though I had an 8MHz crystal attached, without the appropriate fuse settings the mcu will not run at 8MHz
Anyway I used a fuse calculator and changed the low fuse setting through avrdude to accomodate an ext RC osc at 3-8MHz
Yes I know I am not using an RC osc, I am noob, I am assuming this is what has messed everything up and even worse I played around with the vout setting on the usbasp (3.3V - 5V) and I have heard if you are running higher frequencies at lower voltage bad things happen
From then on I can not get avrdude to recognise the atmega8, the odd thing is I keep getting different device signatures every time I try to get avrdude to recognise my device
Is there something I am missing to get this working again?
Is there a simple way to reset the fuse settings??
Thanks for any help, I apologise for my general cluelessness
