- Sat Mar 24, 2012 8:15 pm
#141822
Hello Everyone,
So todays a sad day, I changed the fuse settings on my atmega328p and I cannot reprogram my Arduino Pro any longer. I want to get peoples input on what to do from here.
Reasons I think I bricked it:
* cannot connect to the chip with avr studio using my avrisp.
* I try to change fuse settings but they do not take and am continually getting the giant ISP Mode Error message.
* Cannot read the devices signature.
* avrisp can read and program other chips I have
* when trying to reprogram the Arduino Pro using avrisp I get this error from avrdude
avrdude: stk500v2_command(): command failed
avrdude: stk500v2_recv(): checksum error
avrdude: stk500v2_program_enable(): bad STK600 connection status: Unknown (0x64)
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override this check.
So now the big question is what to do from here. I'm open to any suggestions, I need some good old fashioned advice.
Reason I got into this mess is I was trying to program my pro board from the arduino ide, and was having a heck of a time getting the avrisp to be recognized. I ended up in the fuse section to make some modifications to see if the problem was on the boards end and then it became completely unresponsive.
On a side note, does anyone know if you can use the avrisp in arduino as a programmer, here is a picture of what my programer looks like http://www.raphnet.net/divers/avrprog/avrisp.jpg
Thanks for the help, anything is greatly appreciated
Briscoe B-)
Briscoe B-)
