- Thu Dec 15, 2011 3:37 pm
#137034
I've been playing around with Arduino and now want to make something tiny and standalone. My 'project' is a temperature sensor and RGB LED and display a colour based on the temperature, easy enough to prototype on Arduino, now I want to make it work with as few parts as possible.
I'm considering using a ATTiny13 or ATTiny85, problem is I'm using 3 PWM pins for the LED and these seem to have only 2 PWM pins.
There must be a trick! And if there is, is there also a trick to use only one resistor for the RGB LED or is it always necessary to use 3?
Thanks,
Thanks,
