- Wed Feb 09, 2011 12:33 am
#119736
I am trying to get Sparkfun's Pocket ISP programmer working on my 32bit Windows 7 machine. I have installed the required device drivers, and it is visible in my device manager:
Now, when I run avrdude in command prompt with the following command:
So, what am I doing wrong? Can someone help?
It responds with:avrdude -c usbtiny -B 1 -p m328p -U flash:w:main.hex
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override this check.
avrdude done. Thank you.
