PSMC PIC16F1783
imircea
PSMC PIC16F1783
Post by imircea » Mon Jan 14, 2013 3:34 am
Hi, i got some problem getting started with the PSMC of the PIC16F1783.
I tried also the example frm the datasheet and still got nothing. This is the code i'm using.
Tks for helping.
 __CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _MCLRE_OFF & _CP_OFF &  _CLKOUTEN_OFF
 __CONFIG _CONFIG2, _PLLEN_ON & _LVP_OFF#include <p16f1783.inc>
 org 0x00
 BANKSEL PSMC1CON
 MOVLW 0x02 ; set period
 MOVWF PSMC1PRH
 MOVLW 0x7F
 MOVWF PSMC1PRL
 MOVLW 0x01 ; set duty cycle
 MOVWF PSMC1DCH
 MOVLW 0x3F
 MOVWF PSMC1DCL
 CLRF PSMC1PHH ; no phase offset
 CLRF PSMC1PHL
 MOVLW 0x01 ; PSMC clock=64 MHz
 MOVWF PSMC1CLK ; output on A, normal polarity
 BSF PSMC1STR0,P1STRA
 BCF PSMC1POL, P1POLA
 BSF PSMC1OEN, P1OEA ; set time base as source for all events
 BSF PSMC1PRS, P1PRST
 BSF PSMC1PHS, P1PHST
 BSF PSMC1DCS, P1DCST ; enable PSMC in Single-Phase Mode ; this also loads steering and time buffers
 MOVLW B'11000000'
 MOVWF PSMC1CON
 BANKSEL TRISC
 BCF TRISC, 0
 end
