Sorting Variables
Have you got the greatest 48 bit multiplier ever conceived? Prove it - post your code here.
HappyBomberGuy
Sorting Variables
Post by HappyBomberGuy » Thu Jun 02, 2011 1:34 pm
Anyone have a short code snippet or pseudocode for sorting variable values from low to high?
fll-freak
Contact:
Re: Sorting Variables
Post by fll-freak » Thu Jun 02, 2011 2:21 pm
How many values?
What language?
Looking to optimize speed or code size?
rmteo1
Post by rmteo1 » Thu Jun 02, 2011 2:28 pm
Why use 8 bits when you can have 32?
ARM CORTEX Rules!!! :mrgreen: :mrgreen: :mrgreen:
HappyBomberGuy
Post by HappyBomberGuy » Thu Jun 02, 2011 11:59 pm
Only need to sort 3 variables from low to high, these will change each time through the program so I need to sort them each time. It will be in C.
Longhorn Engineer
Contact:
Post by Longhorn Engineer » Sun Jun 19, 2011 12:26 am
qsort(A,sizeof(A),sizeof(int),compare);
Where A is the array that holds the variables and compare is this function.
int compare (const void * a, const void * b)
return ( *(int*)a - *(int*)b );
More info here. http://www.cplusplus.com/reference/clib ... lib/qsort/
Its in the stdlib of C so you should be fine.
