Best GPRS Rx Buffer Management
SebaS
Post by SebaS » Thu May 05, 2011 9:40 am
Hi all everybody, I've been out for a while...
But here I am wanting to start a discussion about: Which do you think is the best way for manage and process Data Arriving from a GPRS Module?
GPRS modules communicate via AT commands sequences, wich begin and end with <CR> <LF> (0x0D 0x0A)
1- Do you think is better to process the serial data at the moment it arrives? (I mean inside SCI ISR [if used])
2 - Or maybe you think is better to add every input data to a buffer and then process it?
[i]Sebastian M. Irazabal
Electronic Engineer
Rosario, Santa Fe - Argentina[/i]
