Rotomotion's Kalman filter tilt.c by Tom Hudson
rp181
Post by rp181 » Tue Sep 07, 2010 6:09 pm
I recently found Tom's kalman code:
http://www.rotomotion.com/downloads/tilt.c
What kind of values does this take in? Should the input be offset by the zero value?
I tried offsetting the zero value and giving it the raw ADC data (8000 is gyro flat), so Sensor value - offset value.
I get results from the kalman filter, but they do not look right at all. It jumps all over the place, and kind of acts like a out of tune PID loop, but worse.
for (i = 0;i<100;i++) {
		averageSumg += getValue(7);
		averageSumy += getValue(2);
		averageSumz += getValue(3);
		delay(10);
	averageSumg = averageSumg/100;
	averageSumy = averageSumy/100;
	averageSumz = averageSumz/100;
averageSumy, averageSumz);
	while (1){
	for (i = 0; i < 1000; i++) {
		pitchgyro = getValue(7)-averageSumg;
		accely = getValue(2) - averageSumy;
		accelz = getValue(3) - averageSumz;
stateup(pitchgyro);
anglenew = kalmanup(accely,accelz);
