Barrel clearance
Posted: Mon May 01, 2017 4:56 pm
by jwatte
Is there a defined minimum barrel clearance?
I'm looking for a minimum guaranteed clearance between any two barrels (but not necessarily barrel and haybales/side.)
I understand that there's no guaranteed "straight path" though, which is fine, but I need to know how much space there is to maneuver. I'd hope for at least 3 feet clearance ring around each barrel. (Clearance rings may overlap, but the distance between any two barrels would be at least 3 feet.)
Separately, is there a specification of how "rough" the "wall climbing" ramp will be?
What will be the maximum depth of crevices, and maximum/minimum length of span of crevices, and minimum/maximum width of elements?
Or, if this is "glue stuff to a flat board," what are the dimensions of the cross sections of those things?
Re: Barrel clearance
Posted: Tue May 02, 2017 8:50 am
by SFE_Mech_Eng_Evan
jwatte, per your recommendation, there is officially a 36" minimum clearance between barrels, but not from a barrel to the hay-bale wall.
The size, shape, placement, and density of the elements on the horizontal climbing wall is as-of-yet undefined. However, the elements will likely consist of scrap construction lumber (e.g. bits of 2x2, 2x4, 1/2" cladding scraps etc.). Vehicles will not be required to bluntly transcend a vertical of 3 1/2" (the waking edge of a 2x4).
Posted: Tue May 02, 2017 10:38 am
by jwatte
Thanks for the additional information!
Any more information you can share would of course be useful as it becomes available
Separately, if you can provide a number of snapshots of the course elements (various vinyl tapes, pedestrian dummy, etc) taken with different cameras in different lighting environments, ideally from about 1-2' above ground vantage point, that'd be super swell, too!
Posted: Tue May 02, 2017 11:02 am
by jessejay356
On a related note... what happens if a competitor knocks over a barrel and there is no longer a clear route?
Posted: Tue May 02, 2017 11:54 am
by tedmeyers
Can we also get approximate dimensions of the horizontal climbing wall portion (width, length, height)?
[The size, shape, placement, and density of the elements on the horizontal climbing wall is as-of-yet undefined. However, the elements will likely consist of scrap construction lumber (e.g. bits of 2x2, 2x4, 1/2" cladding scraps etc.). Vehicles will not be required to bluntly transcend a vertical of 3 1/2" (the waking edge of a 2x4).[/quote]
Posted: Tue May 02, 2017 12:33 pm
@jwatte
At present, no snapshots have been taken of this year's obstacles, however the hoop and barrels are the same obstacles we've used for AVC in years past.
As we procure supplies (vinyl tape, etc.) for the track and build obstacles, this GitHub repository will serve as home for the images we generate:
https://github.com/ESpitler/AVC2017_images
@jessejay
Given the clearance rule added above, complete obstruction seems unlikely. However, vehicles
are allowed to push or otherwise move the barrels autonomously. If a complete obstruction occurs due to a felling of a barrel, the the vehicle is advised to push through, although this may slow the vehicle's run.
Posted: Tue May 02, 2017 12:42 pm
tedmeyers wrote:Can we also get approximate dimensions of the horizontal climbing wall portion (width, length, height)?
The horizontal climbing wall will be approximately 96" x 96" (two 4'x8' sheets of plywood/OSB/similar) with a rise in the center of no more than 6" (not counting obstacle elements) extending laterally across half of the track.
