PCB with CS8900
Guest
PCB with CS8900
Post by Guest » Mon Oct 13, 2003 4:13 pm
It will be great if you make a board with CS8900 and connector for interfacing uC.
sparky
Site Admin
Contact:
Post by sparky » Tue Oct 14, 2003 9:13 am
Another fun IC! A fully enabled 10mbit ethernet controller.
This is the first thing google popped up:
http://www.seanadams.com/cs8900/
Here is som'more good info:
http://www.wiresncode.com/projects/ether/
OLIMEX
Contact:
Post by OLIMEX » Thu Nov 06, 2003 9:32 am
In matter of fact MSP430-EasyWeb is exactly this kind of board.
It have CS8900 chip connected to MSP430F149 and the TCP/IP stack is open source
Best regards
Tsvetan
nephrozym
Post by nephrozym » Mon Nov 24, 2003 4:52 pm
sparky wrote:Unfortunately, this IC has been discontinued. If there is a new, equivalent, IC out there, please let us know and we can layout a TQFP breakout board for it.
this is probably suitable.
Warper
Where to get the chips?
Post by Warper » Tue Dec 09, 2003 3:50 am
Does anyone know where to buy some (~10) Ethernet controllers? I am flexibly but I just can't find any vendor.
Help!?
Warper
OLIMEX
Contact:
Post by OLIMEX » Tue Dec 09, 2003 4:37 am
We buy ours from Memec
Tsvetan
Guest
Post by Guest » Wed Jan 21, 2004 9:31 am
OLIMEX wrote:In matter of fact MSP430-EasyWeb is exactly this kind of board.
Best regards
Tsvetan
Where can I find the docs for MSP430-EasyWeb (part lists) ?
Guest
Post by Guest » Wed Jan 21, 2004 12:19 pm
the parts list is in the TI appnote, you can download it from TI or Olimex's web
BR
Guest
Post by Guest » Thu Jan 22, 2004 3:40 pm
Anonymous wrote:the parts list is in the TI appnote, you can download it from TI or Olimex's web
BR
Many thanks for your help so far. I noticed that there are assembled easyWeb2 boards.
But I'm interested in a cheaper design without LCD and RS232 and so on. All I need are
4 to 6 10A/240VAC relay outputs. So I thougth the simpler easyWeb board would be a good starting point.
Are there assembled easyWeb boards out there? And what do you think would a simple unit with nothing more than 6 relay outputs cost?
andreas@easyleading.com
OLIMEX
Contact:
Post by OLIMEX » Thu Jan 22, 2004 11:06 pm
Custom boards can be made and assembled up to your specs.
Send your PCB files, Bill of materials and quantity you need for quote.
More info you can find on http://www.olimex.com/pcb/protoa.html
Thanks
Tsvetan
K i W i
Ethernet Controllers
Post by K i W i » Fri Jan 30, 2004 10:11 pm
Check out http://www.edtp.com
The website has many ethernet chips already embedded in nice breakout circuits which makes work alot easier , especially cause each one of these ethernet chips is 100pins + and QFPs ...
RussNelson
Post by RussNelson » Tue Mar 02, 2004 7:57 pm
sparky wrote:Another fun IC! A fully enabled 10mbit ethernet controller.
Thanks! I'm glad you like it.
Are you sure about that? It's still listed on the Cirrus Logic web page, with no indication that it isn't available anymore.
Danne
Post by Danne » Thu Apr 15, 2004 2:55 am
Try these guys,
I have used their IP Dragon (board with CS8900A) in the past with great success. Good board layout with low EMI emission. Currently I am working with a beta board from them which uses a 100MBit ethernet controller and a 16-bit interface. You should contact them directly if you want to know more.
You'll find them at http://www.invector.nu
Regards
Dan the man
sparky
Site Admin
Contact:
Post by sparky » Tue May 11, 2004 7:05 am
I dunno where I got that it was discountinued...
We actually have a batch of IP Dragons on the way from Sweden. We'll get them posted as soon as we can get our grubby mitts on them.
-Nathan
